Mis firing at 80kph
Verfasst: 25.04.2016, 15:26
HI there,
I have a A102 A1 with a Pallas carburetor and recently at 80kph on the dot I start to get a miss fire then 3 or 5 secs later another one.
As soon as I drop to 75kph it stops..
I stripped the carb and cleaned it thoroughly but still the same.
Any suggestions as it seems to be getting a little more often, but that could be because I am not used to setting up a Pallas carb:(
Talking of the carb how many turns out should the mixture screw come out?
Also does anyone have a tuning hints for the carb as there is one other small locking screw that seems to adjust the tick over..
Finally what is better carb, Pallas or Bing for the Heinkel?
Thanks in advance for any help.
Alex
Alex
