Hi All!
I'm in the process og buying a Heinkel trojan -63. One of the objects I'm looking at is a model without the open sunroof (cabriolet!). Just wonder if the trojan has been produced without the sunroof as standard or if the this version is modified.
Regards
Moondog
sunroof on Heinkel trojan -63
ekkesch
Re: sunroof on Heinkel trojan -63
Hallo Moondog,
i am not really shure what you try to find out. At least i can say the original german construction allways had the "sunroof" as emergency-exit. I never saw a car without a "sunroof" just a drawing of the trojan delivery version.
Best regards, ekkesch
Hello,
just have discovered Your mail. There has been a Kabine from Sweden on the 25-ann. -meeting in Lauterburg/Germany. It was modified in several ways. Inside there was installed on the right side a box with the cover from the glove compartment of an old VW bug. The rear-lights also were from the Bug 1960 until 1967. This Kabine in bordeaux-red had a closed tin-roof with two little bubbles over the heads. Maybe it was the car, you´ve seen. It was interesting, but it was not original, no way.
regards, Achim
regards, Achim
