Fahrgestell-Nr./Chassis Numbers?
KarlCooper
Beitrag von KarlCooper »
I've just brought a 1965 103 A-2 and I'm interested to know how close to the end of production it was. Does anybody have a record of the chassis numbers? Thanks.
Erdgeschoss
Re: Fahrgestell-Nr./Chassis Numbers?
Beitrag von Erdgeschoss »
The type A2 beginning with frame No. 0225 001 and a production of about 55.000 units this should put you pretty much in the ballpark assuming consecutive numbering. And why shouldn't it be consecutive, at least they where german. :mrgreen:
KarlCooper
Thank you Erdgeschoss. Very interesting. It looks like another approximately 16,000 units were produced after mine. I965 must have been a busy year as my speedo drive is date stamped March 1965.
thyymo
Beitrag von thyymo »
Are there actually any results from the data collection on chassis numbers in late 2016?
The last proven #´s in the database are:
Model, Frame#, Motor# , Issued paper
103 A2 264267 609359 2/1/1966
What are your # Karl?
Can you please make a picture of your speedo drive with the date stamp?
Between 1963 and 1966 the market collapsed. The manufacturing belt was first shorten and after the demand was reduced further, 103A2 were hand assembled from spare part. Nobody likes to document this negative trend, these days. Therefore the figure of 55000 produced 103A2 is quite insecure.
At the end, the issued paper has no direct relation to the manufacturing date. Lots of Heinkels were waiting in the showroom of the dealer for years.
Anh
KarlCooper
Hi Anh. Thank you for the information. Unfortunately the date stamp is not visible now I have reassembled into the forks. My frame number is 263617. Cheers Karl
thyymo
Hi Karl,
within this forum you can find a file named »Zuordnung Rahmennummer 103 A-2.pdf« (Allocation of Chassis Numbers). In this file the chassis number 0263740 is assigned to the first registration on Juli 1st, 1963.
KarlCooper
Hi Anh. Thanks for the information regarding the pdf. It looks like one four before mine was registered in 1966 ( 0 263 613 - 01.04.1966 ) a year after mine. I guess, we'll probably never be able to really know. If my speedo drive is original then it would suggest mine is later than March 1965. Perhaps if I ever have to split my engine (I hope not) then I might find out more according to - http://www.heinkeltourist.com/dates.htm. Cheers Karl
thyymo
Dear all,
after receiving private messages on this subject, I would like to make a statement. The file I referred to is accessible and viewable even by non-registered users of this Heinkel Forum. This file was neither created nor published by me. Thus I'm not responsible for the correctness of its content. My reference was made with the best intentions. At no time I wanted to spread false information.
Thank you.
