Rahmen measures
Verfasst: 28.12.2005, 10:55
von Rui Tavares
I need your help with the frame (Rahmen) of my Heinkel.
My frame is ab 0205 001
It is a little bent in the front. The front fork (Vordergabel) is ok.
It seems that the front is a bit to the back. It must have had a head on accident.
I need to know the distance between the wheels.
I need to know the angle of the front tube of the frame
I need to know the exact angle of the front fork and all the measures possible.
Can you help me with this?
Thank you.
Associate 6212
Rui Tavares
Portugal
von Matthias Obst
Hi Rui,
I think in this case the best will be to contact Uli Winter from Heinkel-werkstatt.de. His email-adress is info@heinkel-werkstatt.de.
The second point to contact could be motoglaser.de, email adress is info@motoglaser.de.
Both should be able to help you with your frame.
I hope, I could help a bit.
Greetings
Der Püttomane
