sunroof on Heinkel trojan -63
Verfasst: 11.08.2008, 08:49
von moondog
Hi All!
I'm in the process og buying a Heinkel trojan -63. One of the objects I'm looking at is a model without the open sunroof (cabriolet!). Just wonder if the trojan has been produced without the sunroof as standard or if the this version is modified.
Regards
Moondog
Re: sunroof on Heinkel trojan -63
Verfasst: 23.09.2008, 19:22
von ekkesch
Hallo Moondog,
i am not really shure what you try to find out. At least i can say the original german construction allways had the "sunroof" as emergency-exit. I never saw a car without a "sunroof" just a drawing of the trojan delivery version.
Best regards, ekkesch
Verfasst: 24.04.2009, 00:54
von kabinchen
Hello,
just have discovered Your mail. There has been a Kabine from Sweden on the 25-ann. -meeting in Lauterburg/Germany. It was modified in several ways. Inside there was installed on the right side a box with the cover from the glove compartment of an old VW bug. The rear-lights also were from the Bug 1960 until 1967. This Kabine in bordeaux-red had a closed tin-roof with two little bubbles over the heads. Maybe it was the car, you´ve seen. It was interesting, but it was not original, no way. :(
regards, Achim
