Handlebar Switch
Verfasst: 25.02.2012, 13:57
von max57
I am repairing a 1960 103A2 that I restored in 1984. There are several parts on this scooter from the early days of the Club that are functional but imperfect. In particular, the horn and light switch are similar to the original, but do not fit quite right. I would like to know if the switch that the Club sells today is a perfect match to the original. The switch I have requires a wedge made of body filler to fill an approx. 4mm gap, and an extra long screw to fasten it at the top. The control buttons are so worn out after 70,000 miles of operation that I have repaired them with epoxy cement.
Re: Handlebar Switch
Verfasst: 25.02.2012, 18:07
Hi,
the switch that is available in the moment is still not perfect and an original old one is better but it works and it is better than the first ones who got sold by HCD. The control buttons are single available at the club store although they are not mentioned in the parts list.
Good luck Werner
Verfasst: 26.02.2012, 16:56
von max57
When I order the control buttons, what shall I call them so Wolfgang will know I only want the buttons? Thank you for your help.
Verfasst: 27.02.2012, 16:51
von Matthias
Hi Max,
tell Wolfgang, that you only need the green, red and blue button for the switch. He will know what you mean. If not, he can call me and I will tell him ......
Kind regards
