Seite 2 von 2
Verfasst: 10.11.2007, 18:01
von Gleiter2
Hey Rolf -
DANKE !!!
So `was hatte ich mir erhofft !
Vor allem die Hinweise auf Lebensdauer und Silica. Dieses Zeug hat mich auch an meinen Supermotoreifen beeindruckt.
Die Spikes - ich hatte nicht gedacht dass es die noch gibt...
Klasse !
stefan
Re: Reifen
Verfasst: 05.04.2008, 15:20
von Rui
Hi
I need a picture showing the plate that is soldered to the frame where you attach the rubber mountings for the floorboard ina a 103A1 with the oldest frame.
Can you help?
Thanks
Re: Reifen
Verfasst: 16.05.2008, 00:52
von Rui
Dear friends:
I need another help.
Does anyone know the distance between the floorboard and the frame (green line)?
Thank you
Re: Reifen
Verfasst: 19.05.2008, 14:44
Hi Rui,
I just measured my A1. The Distance between the top of the Frame and the lowest place of the Floorboard is 8mm on both sides of the Scooter. I think the Gap depends on in which condition the Rubber mounting Brackets are. Hope i could help you. Werner
Re: Reifen
Verfasst: 19.05.2008, 22:12
von Rui
Thank You.
In mine the distance was a bit more but i corrected it to 10mm.
I think it will be allright now.
Thanks again.
