Hey Rolf -
DANKE !!!
So `was hatte ich mir erhofft !
Vor allem die Hinweise auf Lebensdauer und Silica. Dieses Zeug hat mich auch an meinen Supermotoreifen beeindruckt.
Die Spikes - ich hatte nicht gedacht dass es die noch gibt...
Klasse !
stefan
Reifen
Re: Reifen
Hi
I need a picture showing the plate that is soldered to the frame where you attach the rubber mountings for the floorboard ina a 103A1 with the oldest frame.
Can you help?
Thanks
Can you help?
Thanks
Greetings from Portugal
Rui Tavares
Rolls (Heinkel) Roller
Re: Reifen
Dear friends:
I need another help.
Does anyone know the distance between the floorboard and the frame (green line)?
Thank you
Thank you
Rui Tavares
Re: Reifen
Hi Rui,
I just measured my A1. The Distance between the top of the Frame and the lowest place of the Floorboard is 8mm on both sides of the Scooter. I think the Gap depends on in which condition the Rubber mounting Brackets are. Hope i could help you. Werner
Re: Reifen
Thank You.
In mine the distance was a bit more but i corrected it to 10mm.
I think it will be allright now.
Thanks again.
Thanks again.
Rui Tavares
